I have a Chacon 34126, this is smoke detector that can be used as a sirene, Home assistant detect it as a switch because it send a on/off message when in alert mode but to trigger the sirene we need to send SMOKEALERT=ON on the rflink bus, is it possible with HA?
Ok, I found, simply just send command on in a script loop.
