i managed to get the RFLINK Gateway from nodo to work. so i successfully connected all my covers with RFlinkLoader and configured the covers as follows:
When i trigger a command (UP/DOWN) the cover react, but it moves only a bit. when i click up/down with the remote it goes up/down completely. is this normal? do i have to configure something specific?
As it is now itās not usable, as i would need to trigger DOWN 10 times until the cover reached the bottom. wait_for_ackmade no difference and signal_repetitions is no option either, as it pauses after every movement (~20 cm).
Hope someone has a similiar experience and can help me in the right direction.
i tried out different device ids (read somewhere they need to be close to the original) and different switch channels. sadly nothing helped. they still stop moving afte ~2/3 seconds.
Once covers starts moving there is no reason why it would stop. Your logs seems good to me.
There are other logs when cover stop? Any automation in HA?
No one of this reason seems probable to me, but have you verified that something of this is not happening?:
there are no other logs after they stop. the example above is everything that gets logged.
its actually a pretty clean and new HA installation. so no automation, scripts, scenes, ⦠i just have connected my samsungtv with the integration and installed and configured alexa (haaska). other than that only my RFLink with the covers.
during pairing with RFLinkLoader everything went normal i guess. after paring mode the cover switched shortly. after the pair command again and i got ok back.
I was wondering if there are any logs when it stops.
From your remote (the physical one) there are some cover settings that you play with. One of them are the upper and lower limit. You can read about it here:
there are no more logs after it stops than i sent above.
ah, as up/down on the physical remote are going completely up and down i guess settings were programmed correctly. but iāll definetly try out overwrite them or at least play around with them.
in the video they say if a blind is part of a group (i have a telis 4 remote with 5 channels and 4 blinds) i have to disconnect every other blind except the one i want to program before i play around with those settings. but i cannot really get to the power access of the others, do you mean i still can program those settings as described in the video, without unplugging the others?
well, you already gave me one tip that i can now try. iām grateful for that - thank you
I think it should be possible. The problem you may have is that when you try to put the cover in programming mode, it activates in more than one cover you want to program and you end up having strange effects.
If cover reacts as expected with remote but works weird with HA there will be another problem.
Can you try to config and pair a new remote code? This time use a device code more similar to the remote one, something like rts_94c048_01 or maybe rts_94c064_01.
By the way, the aliases part in the post is the real one? Are all overs controlled with the same remote rts_94c044_01 ?
Another question, are you using an specific Somfy RFLink?
I mean, ānormalā RFLink is an 433,92Mhz device, and Somfy covers works in 433,42Mhz. Are you aware of this?
I think that would rather cause a problem in signal sending and not that kind of behavior, butā¦
ill try it and will report if setting the top and bottom standard helped - i can try it out tomorrow.
i already tried this, because i read it in some forum. i only changed the last digit of the hex code - sadly had the same result.
all covers are controlled with the same remote (telis 4). each channel controlls its own cover. the last channgel controls all of them together. each alias is different and has its own device id as you can see in the config.
yes im aware of that. this is why i bought the recommended device from the nodo shop. specific for somfy rts devices in the 433,41Mhz zone. this is the device i use: RFLink 433 (Somfy RTS) / Arduino / Dipole / USB cable
another thing i noticed is, that when flashing the rflink R48 firmware it always says V1.1 - R48 and in the documentation of rflink on HA it says it was tested on V1.4/RFLink R46. is that a mistake in the documentation? i did not find any v1.4.
so after playing around a bit more and dozens of clearing, resetting and pairing iāve got it at least to work a bit better. they still dont go completely up and down, but at least they move way longer now.
The change that made the difference was toggling 10;RTSLONGTX; to ON.
So i configured signal_repetitions in the device_defaults to 2.
Thats not the final solution, but one that i can live with for the next time. Iāll come back later if i have some more freetime to do so.
have you tried to change your covers from US-mode to EU-mode? at the beginning of my configuration with rflink and somfy covers i experienced the same problem. after switching each blind/cover to EU-mode this behavior was gone.
neither one of them! you have to configure your cover with your original somfy remote. my blinds. to switch between US and EU mode you have to simultaneously press UP and DOWN on your remote for 5 seconds. cover should move up/down. the you press MY and DOWN simultaneously for 2 seconds. cover moves again! this should switch modes.
iāve just changed the mode of all my covers. and that was it.
i turned off longtx again, and now the covers move completely up and down with one command, and i can use the stop comand as expected (that wasnāt the case with longtx before). thank you two so much! @tamwoe & @javicalle
I found that information in a pdf document. That was a manual of my blind motor (J406 RTS). In one chapter itās mentioned that the motor is in US mode by factory default and with the above method you can switch between US and EU mode and reverse. In US mode a short press of the UP and Down button makes the cover go up or down completely. A long press configures the tilt. EU mode is the opposite. A short press configures tilt and a long press makes the cover go down or up completely. Hereās the manual but itās in german:
