I am trying to get my Somfy RTS sunscreen integrated in Hassio with the RFlink.
I have already configured the RFlink hub in Hassio with succes like this:
I don’t know where to go from here? What should I do now?
RTS Record: 3 Address: 02FFFF RC: 0413 what can I make from this to add in my cover.yaml?
I also haven’t seen my sunscreen go up and down shortly while pairing?
Is there someone out there who can point me in the right direction?
If your sunscreen has not made the up&down move, it is sure that it has not been paired.
You should keep in mind that you need an specific RFLink for the frequency of Somfy RTS.
If not, it will be very difficult for you to operate the blind beyond a couple of meters away and with direct vision (no walls in the middle).
Thank you for your reply.
I have tried it with some cheap chinese superheterodyne receiver WL101-341 and transmitter WL102-341.
I also have a receiver RX470-4 but I think it is the same.
The receiver should not be a problem, but the transmitter has to be specific for RTS. All this transmitters have a 433.92 MHz frequency (RF), but RTS use a 433.42MHz frequency.
With a RF transmitter it will be almost impossible for you to control yours sunscreens.
On the other hand, if you have a RTS transmitter, you can control the RTS devices and almost certainly you can also control the normal devices (the RF ones).
I started just like you, and I could barely control a cover in the same room. With a RTS transmitter I can control 3 RTS blinds and 2 RF devices distributed between 4 rooms.
What I did was buy an STX882 transmitter and replace the oscillators with a 433.42Mhz from ebay.
Ive got same issue. I have paired my RFLink with the blinds using RFLink Loader and managed to control my blinds with it 10; RTS; 0F0F0F; 0; UP;
But when i added it to my HA configuration:
it creates cover.living_room_blind entity but it neither operates the blind, nor detects state changes by my remote RTS_8ed72c_01.
I have tried changing RTS_0F0F0F_0: to RTS_0F0F0F_1: as on some configurations i found online, but still doesnt work
Thanks, i didnt realize that putting rflink in debug mode will actually allow me to see the received messages.
Thats what i see when i try to control blinds through HA:
Based on this, i have already figured out that the RTS ID is case sensitive, changed remote’s id from RTS_* to rts_* in my configuration and now the remote operations are actually reflected in HA. I still dont know why i cannot control the blinds though.
So i paired all of my blinds to unique id’s in the Rflink loader. Via de Rflink loader i’m able to controll my blinds. Up, down and stop is all working well.
But when configure HA(following that manual and your respons) to controll the blinds, they blinds won’t react.
So I see no reason why it shouldn’t work if it’s already working from Rflink loader.
Is the RFLink specific to RTS? If not, the range is usually very, very small.
Have you tried in HA from the same location you tried with the Rflink loader?
