I could use some help to figure why my RFlink switch (Kaku remote) stopped worked. I used the kaku remote to trigger automations. Without changing my code, nor hardware they stopped working.
I’ve added debug logging mode for the RFlink component, which tells me that the events are being passed to HA.
2019-01-06 14:55:15 DEBUG (MainThread) [rflink.protocol] received data: 20;02;N
2019-01-06 14:55:15 DEBUG (MainThread) [rflink.protocol] received data: ewKaku;ID=0049c0d2;SWITC
2019-01-06 14:55:15 DEBUG (MainThread) [rflink.protocol] received data: H=2;CMD=ON;
2019-01-06 14:55:15 DEBUG (MainThread) [rflink.protocol] got packet: 20;02;NewKaku;ID=0049c0d2;SWITCH=2;CMD=ON;
2019-01-06 14:55:15 DEBUG (MainThread) [rflink.protocol] decoded packet: {'node': 'gateway', 'protocol': 'newkaku', 'id': '0049c0d2', 'switch': '2', 'command': 'on'}
2019-01-06 14:55:15 DEBUG (MainThread) [rflink.protocol] got event: {'id': 'newkaku_0049c0d2_2', 'command': 'on'}
2019-01-06 14:55:15 DEBUG (MainThread) [homeassistant.components.rflink] event of type command: {'id': 'newkaku_0049c0d2_2', 'command': 'on'}
2019-01-06 14:55:15 DEBUG (MainThread) [homeassistant.components.rflink] entity_ids: ['switch.kaku_living_2']
2019-01-06 14:55:15 DEBUG (MainThread) [homeassistant.components.rflink] passing event to switch.kaku_living_2
2019-01-06 14:55:15 DEBUG (MainThread) [homeassistant.components.rflink] Fired bus event for switch.kaku_living_2: on
Here is my code for the automation trigger:
- platform: event
event_type: button_pressed
event_data:
entity_id: switch.kaku_living_2
state: 'on'
Did I miss a breaking change? How to continue unraveling this mistery?
