Currently I’m setting up home assistant. Since I couldn’t control my (rflink) lights in 0.40 I tried to see if there was a update available. So now I have home assistant 0.41.
However while restarting home assistant I got the following errors in my logfile:
17-04-02 12:59:15 ERROR (MainThread) [homeassistant.config] Invalid config for [sensor.rflink]: [new_devices_group] is an invalid option for [sensor.rflink]. Check: sensor.rflink->new_devices_group. (See ?, line ?). Please check the docs at https://home-assistant.io/components/sensor.rflink/
17-04-02 12:59:15 ERROR (MainThread) [homeassistant.config] Invalid config for [light.rflink]: [new_devices_group] is an invalid option for [light.rflink]. Check: light.rflink->new_devices_group. (See ?, line ?). Please check the docs at https://home-assistant.io/components/light.rflink/
My configuration looks like this:
# rflink connection
rflink:
port: /dev/ttyACM0
wait_for_ack: True
reconnect_interval: 30
ignore_devices:
- ev1527_*
- mertik_gv60_*
- fineoffset_0000_*
- platform: yr
- platform: rflink
new_devices_group: "Onbekende Sensoren"
devices:
oregontemphygro_128d4_temp:
name: "Temperatuur Achtertuin"
sensor_type: temperature
oregontemphygro_128d4_hum:
name: "Vochtigheid Achtertuin"
sensor_type: humidity
light:
platform: rflink
new_devices_group: "Onbekende KaKu"
devices:
newkaku_00e485f2_1:
type: dimmable
newkaku_00e485f2_2:
type: dimmable
newkaku_00e485f2_3:
type: dimmable
newkaku:
type: dimmable
And on the main interface I get the following message:
The following components and platforms could not be set up:
sensor.rflink
light.rflink
Please check your config
If I comment out the “new_devices_group” lines than home assistant works mostly as expected but all the rflink weather sensors show up as weather icons (and there are quite a few)
Any ideas what could be causing the errors I’m getting and how to fix them?
