Hello, I am moving to a new Home Assistant build (upgrading hardware… yay!). Previously I had set up somfy blinds in yaml and then RFXCOM made its amazing transition to the GUI integrations and the yaml codes for the blinds were cleaned up and its worked rock solid since.
I really want to start on a clean install after too much tinkering, does anyone know if you can access the device IDs from the config so i can paste the directly into the GUI? I renamed them to be more helpful. I searched high and low through the documentation and the config and I am either a numpty or its tricky to find… rather not have to go back and create if i can avoid it.
Thanking you for reading (hopefull helping) this!
