Finally RFXCom has added support for the Itho ECO protocol @868MHz, and this makes it possible to send/receive commands to/from the home ventilation system.
Would be great if this integration also provides support for this protocol.
The remote control can send the following commands, according to RFX Manager
10-1-2023 03:45:17:464= 140100010255110000004002001C05500000000000
Packettype = Interface Message
subtype = Interface Response
Sequence nbr = 1
response on cmnd = Get Status
Transceiver type = 868MHz
Firmware version = 1017
Firmware Type = Pro1
Noise level = 80
Transmit power = 10dBm
Hardware version = 2.0 RFXtrx868X
Debug off
Alecto ACH2010 disabled
Alecto WS5500 disabled
La Crosse disabled
Davis EU disabled
Davis US disabled
Davis AU disabled
FS20 disabled
LightwaveRF disabled
Edisio disabled
Visonic disabled
Meiantech disabled
Proguard disabled
Itho CVE RFT disabled
Itho CVE,HRU ECO enabled
Orcon disabled
Itho CVE-S,HRU400 disabled
Honeywell Chime disabled
KeeLoq disabled
10-1-2023 03:45:17:684= 1401070207436F7079726967687420524658434F4D
10-1-2023 03:45:23:711= 08170D0074C50701B0
Packettype = Fan2
subtype = Itho CVE-S,CVD-S,HRU ECO / HRU400
Sequence nbr = 0
ID = 74C507 decimal:7652615
Command = Low
Signal level = 11 -32dBm
10-1-2023 03:45:30:815= 08170D0174C50701B0
Packettype = Fan2
Sequence nbr = 1
Command = Low
10-1-2023 03:46:42:970= 08170D0274C5070350
Packettype = Fan2
Sequence nbr = 2
Command = High
Signal level = 5 -80dBm
10-1-2023 03:46:44:942= 08170D0374C50702D0
Packettype = Fan2
Sequence nbr = 3
Command = Medium
Signal level = 13 -16dBm
10-1-2023 03:46:47:676= 08170D0474C50704D0
Packettype = Fan2
Sequence nbr = 4
Command = Timer 15 minutes
10-1-2023 03:46:49:093= 08170D0574C50705D0
Packettype = Fan2
Sequence nbr = 5
Command = Timer 30 minutes
10-1-2023 03:46:50:445= 08170D0674C50706D0
Packettype = Fan2
Sequence nbr = 6
Command = Timer 60 minutes
Signal level = 13 -16dBmtype or paste code here
Thanks,
Marck
