RFXcom configuration with brel
Knipsel 2 Dear people, I started using my transceiver from RFXcom today.
For the most part this went without saying until I wanted to add my Brel roller shutters.
I downloaded the Rfxmngr linked the original remote control. The file below rolls out there.
I think everything is good so far. Now I will reconnect the transceiver to my Raspberry Pi running Home Assistant. Now I have created a switch here and added the following. See photo below. It concerns the blue shaded area.
Now the 2 other shutters work except the one that is shaded blue.
Can you help me solve this problem.
Thanks, Gr VlakKnipsel 1
You made a typo. automatic_add: true and not treu
Dear Francisp ,Knipsel You’re right, but I corrected this yesterday. This is the last pic.
but it also does not work with correction.
I’m not sure the confirm/pair command is the one you need for your switch.
Try and capture the on/open or off/close command instead and see if that works…
I have linked once again with new id and a different command.
but this does not work. I get the following message:
Cannot call service switch / turn_on ‘RollerTrolDevice’ object has no attribute ‘send_on’
- platform: rfxtrx
  automatic_add: true
  signal_repetitions: 1
  devices:
    09190611010101110100 :
Maybe this device / command is not supported?
Try and raise an issue on github to get the maintainer’s attention
Could you save this?
I just got a brell motor with a remote control in 433 range. Im trying to add it now but i don’t know how to do it.
Would be great if you could help me!
