Good morning all. Since the migration to the newer hassio i was facing how to manage new switches, lights for my kaku switches. I didnt find any on the forum ( maybe it was me ) but however i want to share how to add new switches in hassio.
First go to the intergrations
Then select options on the RFXCOM tab
Then you insert a code generated by going to home-assistant-IP:8123/dev-template
Use the following codes to generate an event:
SWITCH: ARC
0b11000{{ range(100,700) | random | int }}bc0cfe0{{ range(0,10) | random | int }}010f70
LIGHT: ARC
0b11000{{ range(100,700) | random | int }}bc0cfe0{{ range(0,10) | random | int }}020f70
LIGHT: LIGHTWAVE RF
0a14000{{ range(100,700) | random | int }}bc0cf{{ range(0,10) | random | int }}100f70
use the generated code to paste into the code in the intergrations. Click on save and now you have a new switch, light etc.
hope this is helping out.
