RFXCOM klikaanklikuit not visible in Devices or Integration
Dear All,
First of all. Hi y’all! I’m new here and started to fiddle with a virtual machine version of Home Assistant together with RFXCom and Zigbee2MQTT. Both are working nearly as expected. I have a question though:
My Zigbee devices are neatly showing up under Devices and under Integration. The KaKu (klikaanklikuit) devices which are found using the RFXCom USB device are usable, but are not added to the Devices tab. I can configure them in the configuration file after I found them and use them as entities, but it would be nice to be able to see them in the devices tab as well. Am I doing something wrong or is this by design?
Thank you very much for your insights in advance!
WizzyWizz
Not all integrations , including rfxtrx show under devices.
Hi there Francisp,
Aha. Ok. Appreciate your quick response. I thought I did something wrong. Good to know that isn’t the case :slight_smile:
Kind regards,
WizzyWizz
