RFXCom loses entity after HA reboot
I’ve been running into an issue. I use RFXCom to control my KAKU/COCO plugs. And I recently added my 19th device to the integration.
After i add it, it works fine. I’ve can use in in HA and automations. But as soon as i reboot HA. The device can’t be used anymore.
Looking at the configuration of the integration, i only see 18 devices. If i download the diagnostics, it only hold 18 device_ids.
I generated a new ID, add it to the integration. Reboot HA. Same issue.
I’m running HA OS 2022.7.3 on a Raspberry PI4 2GB.
And just to be clear, i’ve upgraded to 2022.7.3 last night, was running 2022.7.2 before that.
Do you guys have some tips to investigate this further or a workaround to fix this?
Thanks in advance.
Hi.
It seems like RFXCom RFXtrx is broken in Core 2022.7.x. I have identical problems and I also have a big lag in RFXCom lights, when automation triggers it takes two-three seconds before lights turns on.
I rolled back to Core 2022.6.7, Supervisor 2022.07.0 and OS 8.2 and everything is working as expected with no lag and I can add/remove devices.
/Janne
The problem is solved in 2022.7.6.
/Janne
Hi Janne,
Sorry for not responding to your earlier message.
And thanks for the update. I will test this soon. I hope it will be fixed for me as well.
Updating to 2022.7.6 has fixed it for me as well.
