Hi Everyone,
I’ve just made the switch from Domoticz to HA and am loving it so far! I do have a minor issue with range for my RFXCOM hardware and am wondering if anyone can give me some guidance.
I have two devices (a temp sensor, and a switch) located two floors down that are unable to communicate with HA. Both devices work absolutely fine with Domoticz using the same hardware (Raspberry PI3 + RFXtrx433E), if I just swap out the SD card and run Domoticz everything works fine, while with HA, the two devices drop out.
I came across a similar discussion where there were recommendations of using a powered USB hub, which I’ve ordered, however this was not confirmed as having resolved the issue. I was wondering in the meantime if anyone has other advice.
Thanks everyone!
