I have a blind/cover which got automatically added in HomeAssistant with the “enable automatic add” function an pressing the remote control of the blind.
With this blind, also a Sensor was added, but the blind has no sensors.
It is an awning/marquee.
But the blind has an light integrated. How could I add the light to HomeAssistant?
In the RFXmngr there a controls for the blind and for the light.
Thx.
what do you mean with “test under Rfxmngr if the commands pass”?
I can switch the light with the remote control and with the RFXmngr. (The light is physically switched.)
But not within HA and the RFXTRX Integration, because it get not automatically detected.
I think what he means is, run Rfxmngr on a computer, send the on and off command for the light using the remote and catch the code that was sent, then you can create a light manually in HA using the data Rfxmngr received…
If you’re trying to add the blinds to HA, I can’t remember exactly how I did it, but I think I enabled automatic add in RFX Config then pressed the buttons on the remote.
Additionally you can set your debug mode to catch the code
automatic add worked only for the blind/cover (awning) but not for the light in the awning.
I pressed 2 times the ligth button with debug mode. Here’s the output:
@011V32 to be honest It’s been a long time since I added a new RFX device to my config.
Have you tried to click on configure for your RFXTrx integration and add 09190604e1127d050582 in “enter event code to add”
Only thing is you may have to play with the protocol as I guess it’d be set as a blind if you chose any of the blind protocols. Maybe you need to create an issue in github to ask for your blinds’ light to be added?
