Rfxcom / Rfxtrx433e ID codes for Westinhouse Fans
Is there a way to find out the ID code for a westinghouse fan. I have used the RFX manager on the PC and can control the fan perfectly well, it seems to have four switches to pair the fan and remote and then sends the control, but I cannot get from there to getting it to work in home assistant.
I already have energenie and lightwave devices working so I know my config is basically right, home assistant works fine with those, but I used a python script to generate the ID codes for those which doesnt include the fan. I also have a few cheap chineese binary switches on doors which simply appeared in the devices list so that was easy.
But, the fans do not appear no matter how many buttons I press, and its frustrating to know I can control them using the rfx manager on the pc, but have no way of finding out what I need to send from home assistant.
If anyone can help I would really appreciate it. I guess it also applies to any less common device.
I was using a broadlink before and these were my codes. They may work for you.
#- platform: broadlink # office broadlink
#  host: 192.168.1.13
#  mac:  'B4:43:00:00:00:00'
#  timeout: 15
#  switches:
#    fan_office:
#     command_on: 'JgBiACkOKg4NKg4pDiopDg4pDioNKg0qKQ8p6ykOKg4NKg4pDiopDg4pDikOKg0qKQ4q6ykOKg4NKg4pDikqDg0qDikOKg0qKwwq6ysMKwwQKA8oECcsDA8oECcQKA8oKwwsAA0FAAAAAAAA'
#     command_off: 'JgBoACkOKg4PKA4pDioNKg0qKQ4OKg0qDikOAAEHKwwrDBAoDygPKBAoDygrDBAoDygPKBAAAQUrDCsMECgQJxAnEScPKCsMECcQKBAnEAABBSoNKw0OKQ4pDikPKA8pKg0QJw8pDikPAA0F'
#    fan_to_hi:
#    fan_to_medium:
#     command_on: 'JgBoACkOKQ4OKQ4qDSoOKQ4qDSoOKSoODSoOAAEGKg4pDg4pDioNKg4pDioNKg4pKQ8NKg0AAQcqDikODikOKg0qDSoOKQ4qDSopDg4qDQABBykPKQ4NKg4pDioNKg4pDioNKikODioNAA0F'
#    fan_to_low:
#     command_on: 'JgBiACsMKg4PKBAnECgPKA8oECcRJxAnECcs6SsMLAwPKBAnESYQKBAnESYRJw8oECcr6ioNLAwOKQ4pDygPKQ4pDikPKA8pDikq6yoNKw0OKQ4pDikPKA8pDikPKA8pDikqAA0FAAAAAAAA'
#    fan_light:
#     command_on: 'JgBoACoOKQ4OKQ4qDSoOKQ4qDSopDg4qDSoOAAEGKg4pDg4pDioNKg4pDioNKikODioNKg0AAQcqDikODikOKg0qDikOKQ4qKQ4OKQ4qDwABBSsNKwwPKBAnECgPKBAnECgrDBAnECgPAA0F'
#    command_off: 'JgBoACwMKwwQJxEmEScQJysMECgQJxAnEScQAAEEKwwsDBAnESYQKBAnKwwQKBAnECcQKBAAAQQrDCwMDygQJxEnECcrDBAnECgPKBEmEQABBCsMLA0OKA8oECcQKCoNECcQKA8oECcPAA0F'
