RFXCOM sensors "sensor status" never change
I’m french user of home-assistant (v0.66.1).
Of all home automation software is the one I prefer, so I keep it and thank you for the work done!
I use a rfxcom box with door open sensors and motion detectors known as RFXtrx Sensor by HA.
The problem is that once a sensor has changed its “sensor status” for “ALARM” or “PANIC” it does not return to a neutral state.
There had been a topic (Smoke detector are not changing from “Panic” state) on github but I don’t know if a solution was found.
it would be very useful for me to create scenes or automations.
Thank you,
Bests Regards
