The ID is: C 1C 1C
The Unit codes is: 3
RFY command is: 0C 1A 00 20 0C 1C 1C 03 08 A5 00 05 00
idl-3 is : 0C1C1C decimal: 793628
The RFXCOM RFXtrx manuel is mentioning:
Make a note of the assigned ID and Unit Code and then add a device to the configuration with the following id 071a0000[id][unit_code]. E.g., if the id was 0a 00 01, and the unit code was 01 then the fully qualified id would be 071a00000a000101, if you set your id/code to single digit in the rfxmngr, e.g., id: 1 02 03 and unit code: 1 you will need to add 0 before, so 102031 becomes 071a000001020301
So in my case this would be?
071a0000[793628][03] 071a000079362803
Or must it be:
071a0000[0C1C1C][03] 071a00000C1C1C03
Or any other combination?
Please help donât get it working
What are you trying to accomplish hereâŠe.g. my for my (old) somfy garagedoor, I had to sync the rfxcom with the motorcontrol, ie. I myself (!) defined the code and then sent it to the opener where I had to click a button and pair it
Did you try to enable the auto discovery within the RFXTRX integration ? I used it recently with a motion detector and it worked perfectly. The entity was added automatically in home assistantâŠ
you can try to send the same command as the Rfxmngr, for your cde must be of type 0C1C1C03
0C1A00xx0C1C1C03yyA5000500
0C Leng
1A00 Protocol Type ( RFY)
xx nbr 00->FF
0C1C1C ID
03 Unit Code
yy de 00 ->14 command (08 *Program (transmit > 2 seconds)
A50005 fu1/2/3
00 RSSI
Not sure if you have seen this but there is a specific section where âmyâ somfy solution is dealt with and yours seems very similar to what I needed RFXCOM RFXtrx - Home Assistant (home-assistant.io)
So⊠I believe your second code is ok but⊠the up and down do NOT work with meâŠ
I am using this one it only fires one code which does start/stop and depending on the state it goes up or down
I just added my device which then provided me this âcoverâ buttons option for the up/square/down and up/down donot work, only the squareâŠwhich is logical in my situation as it exactly simulates my somfy remote (fire and forget)
imho it is the second code based on your upper most screenshot (another feedback mentioned similar to use that). One thing that may frustrate testing is if you have two âintegrationsâ connected to the rfxtrx, i.e. if I connect with rfxmgr as the same time then HA is not always workingâŠso disconnect that.
All in all⊠I donot want to say that my journey has been easy as well, took a while to get this all setup and havent touched it in 6 months so part of it sunk back in memoryâ.
Just to recap what I did
used rfxmgr to setup/choose the codes (not the default values) and pair with the somfymotor
test it from rfxmgr after I placed the rfxtrx on the intended location
added it via the code to HA
then needed to identify which switch/cover/etc. actually worked for me
