I have 10 KERUI doorsensors.
One of them does not work ok.
It makes two binary sensors in HASS
binary_sensor.bbsb_new_types_07cd26_1 gesloten
binary_sensor.bbsb_new_types_07cd26_4 open
debug
2023-08-16 14:26:14.160 DEBUG (MainThread) [homeassistant.components.rfxtrx] Receive RFXCOM event: {'packet_type': 20, 'sub_type': 2, 'type_string': 'BBSB new types', 'id_string': '07cd26:4', 'data': '0a14027d07cd2604010060', 'values': {'Command': 'On', 'Rssi numeric': 6}}
2023-08-16 14:26:14.162 DEBUG (MainThread) [homeassistant.components.rfxtrx.sensor] Sensor update (Device ID: 07cd26:4 Class: LightingDevice Sub: 2)
2023-08-16 14:26:14.164 DEBUG (MainThread) [homeassistant.components.rfxtrx.binary_sensor] Binary sensor update (Device ID: 07cd26:4 Class: LightingDevice Sub: 2)
2023-08-16 14:26:16.525 DEBUG (MainThread) [homeassistant.components.rfxtrx] Receive RFXCOM event: {'packet_type': 20, 'sub_type': 2, 'type_string': 'BBSB new types', 'id_string': '07cd26:1', 'data': '0a14027e07cd2601000050', 'values': {'Command': 'Off', 'Rssi numeric': 5}}
2023-08-16 14:26:16.527 DEBUG (MainThread) [homeassistant.components.rfxtrx.sensor] Sensor update (Device ID: 07cd26:1 Class: LightingDevice Sub: 2)
2023-08-16 14:26:16.529 DEBUG (MainThread) [homeassistant.components.rfxtrx.binary_sensor] Binary sensor update (Device ID: 07cd26:1 Class: LightingDevice Sub: 2)
is it possible to correct this, and have one binary sensor with open and close ?
my other kerui sensors do work like that, this one is different…
an option is to change one of the binary sensors when the other is activated.
I could find an option for this within the automation/actions.
With the developertools i can change the value of this binary sensor
i have a workaround with an automation, but want to have a better solution (and learn more about HASS
workaround
alias: testrfx
description: test
- platform: event
event_type: rfxtrx_event
event_data:
packet_type: 20
sub_type: 2
id_string: 07cd26:4
values:
Command: "On"
condition: []
- service: tts.google_translate_say
entity_id: media_player.chromecast_huiskamer_nest
message: hallo, test is gelukt
cache: true
language: nl
mode: single
