RFXCom. Unable to connect to rfxtrx device in setup
Hi all,
I am in the process of migrating my home automation from domoticz to home assistant. Everything is running smoothly so far. Zigbee, Zwave, shelly devices, netatmo devices, homekit locks and cameras, … but now it’s the turn of RFXcom integration and I’m absolutely unable to make it run. My RfxTrx433XL transceiver is working fine in a Proxmox Debian VM where Domoticz is running. When I move the transceiver to the Debian VM where Home Assistant is running, HA Rfxcom Integration tells “Unable to connect” when /dev/ttyUSB1 is filled in the box “path to usb device”. The usb device is well created in the VM, permissions are ok, group dialout is well configured, transceiver is not locked by previous applications (Domoticz VM is shutdown), … everything seems to be as it’s expected to be but … “Unable to connect”, always. Any suggestions about what I can check next?
