I am getting the error logs:
2021-08-11 16:22:29 ERROR (Thread-4) [root] Uncaught thread exception
File “/usr/local/lib/python3.9/threading.py”, line 973, in _bootstrap_inner
self.run()
File “/usr/local/lib/python3.9/threading.py”, line 910, in run
self._target(*self._args, **self._kwargs)
File “/usr/local/lib/python3.9/site-packages/RFXtrx/init.py”, line 876, in _connect
self.transport.reset()
File “/usr/local/lib/python3.9/site-packages/RFXtrx/init.py”, line 723, in reset
self.send(b’\x0D\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00’)
File “/usr/local/lib/python3.9/site-packages/RFXtrx/init.py”, line 719, in send
self.serial.write(pkt)
AttributeError: ‘NoneType’ object has no attribute ‘write’
2021-08-11 16:22:31 WARNING (MainThread) [homeassistant.setup] Setup of input_number is taking over 10 seconds.
2021-08-11 16:22:31 WARNING (MainThread) [homeassistant.setup] Setup of input_text is taking over 10 seconds.
2021-08-11 16:22:31 WARNING (MainThread) [homeassistant.setup] Setup of counter is taking over 10 seconds.
2021-08-11 16:22:59 ERROR (MainThread) [homeassistant.components.rfxtrx] Connection timeout: failed to receive response from RFXtrx device
2021-08-11 16:23:03 WARNING (MainThread) [zeroconf] Error with socket 22 ((‘fe80::6af5:14a4:914a:4fea’, 5353, 0, 2))): [Errno 101] Network unreachable
File “/usr/local/lib/python3.9/asyncio/selector_events.py”, line 1056, in sendto
self._sock.sendto(data, addr)
OSError: [Errno 101] Network unreachable
This was working fine in my antique april version. I am running HA under docker, and I am passing in the appropriate port ( --network=host
–device /dev/ttyUSB-ZStick5
–device /dev/ttyUSB-RFX433XL
What am I missing?
