RFXlan configuration possible?
Hi all,
is it possible to connect my RFXlan to HomeAssistant?
Google wasn’t the solution this time.
Perhaps someone know something how to use the RFXlan?
tnx in advanced!!
kind regards,
Jean-Paul
Hello
I have the same question … I just forwar to support from RFX team.
jk
Yes possible, I have RFXCOM on LAN working OK HA
IP and Port address recovery, check on Rfxmngr if OK
Attention if automatic addition, the identities go up quickly, do not leave!
Je suis Français
Oui possible, j’ai RFXCOM sur LAN fonctionnement OK HA
Récupération adrsse IP et Port , vérifier sur Rfxmngr si OK
Attention si ajout automatique, les identités montent vite, ne pas laisser !
Summary
@+Dom
Hello
This my answer from RFXCOM
The RFXLAN is not supported by HA and cannot be supported as we don’t have a SDK for this device.
The only software that supports the RFXLAN is Homeseer.
Did you cange anyting in setup ?
regards
Jonny K
Hi
Does your RFXCOM LAN work under Rfxmngr?
There is no modification in the configuration, only the choice of the network port during the installation
repeat information above
Do you have the ‘Select connection type’?
Français
Slt
Votre RFXCOM LAN fonctionne -t’il sous Rfxmngr ?
Il n’y a pas de modification dans la configuration, seulement le choix du port network lors de l’installation
reprise information ci-dessus
Avez-vous le “Select connection type” ?
@+Dom
The very old RFXLAN and the RFXtrxLAN are different devices.
The old RFXLAN can’t be supported by Home Assistant.
The interface protocol of the old RFXLAN is totally different and for this reasson you can’t use RFXmngr.
Thanks again … For the moment I use homeseer to send me data but later I will just buy a now one :slight_smile:
jk
If anyone is interested, I made a small utility to forward the xPL messages of the RFXLAN to mqtt, so while I haven’t tested everything, it shoud work pretty well for basic use cases in home-assistant. (just sharing it here in case it can help some people, but I probably won’t have time to provide much support).
