Rfxtrx 0.117 repeat option, is it still in?
Hi all,
I updated to 0.117 about a week ago. Since that day, I see a lot of KAKU missing commands. As I understand, the yaml is dropped as of 0.117. It’s now a full integration. However I used to have signal repetitions set in my yaml, but I don’t see that option in 0.117 anymore. It’s still in the docs, but nowhere to be found (I think). So two questions:
Is it still there?
if so, how to set the signal repetitions?
Thanks,
Ralph
Go to Configuration->Integrations in your UI, select the options button on the rfxtrx card. In the first window, under “Select device to configure”, select a device and press “Submit”. In the next window, you should be able to set the number of repetitions.
Ok, thx! will give it a try…
