my RFXtrx works fine with my solar somfy cover.
I try to do the same with my somfy portal.
I have used rfx manager and under it it works well. Like this I have an ID that I have reported into homeaasistant. Homeassistant found the entity but the buttons doesn’t work (they were working fine with rfx manager).thanks
How did you come to the event code you added to Home Assistant?
Hello
I get it works. I hat made a mistake between the id -3 and the decimal
the good one was 071a00000FF0F101.
I have fans that I wanted to add too but the id in rfxmngr is like that
Packettype = Fan
subtype = Lucci Air DCII
Sequence nbr = 64
ID = SW1=On, SW2=On, SW3=On, SW4=On
Command = Speed 6
Signal level = +10 dBm
Do you think we can add it too?
There is unfortunately no fan support in Home Assistant and the pyRFXtrx library.
You could send some commands with the rfxtrx service call to control the device.
thanks for your help.
could you explain me how to do it?
Anyone got the fan working in HA? I have a Faro Barcelona which I had working in Domoticz with the RFXCom device and installed like a Lucci Air fan… need to put it into HA now…
still looking for a souce too
