RFXtrx doorbell sensor
I have some Siemens RF433Mhz Door sensors with magnet (Model DCACC4) they only send a signal when the door is opening.
The signal is only 14 and it stay 14 even if i close the door and open it again.
I have added the fire_event: true but it still says 14.
 - platform: rfxtrx
   automatic_add: true
   devices:
     07160012009f0e70:
       data_type:
       - Sound
       fire_event: true
Any help or will they have to be put in the bin?
Since your senor only sends a signal when the door is opening, the state will always be 14.
If you want to use your sensor for automation, you can listen for the fired event:
