I have a Telldus outdoor switch that used to have entity ID like 0b11000685bc0cfe05010f70 but after upgrading hassio it has changed (i think). I have one rfxtrx433e connected to my hassio machine. I do NOT have any telldus stick. The telldus remote is also gone so I can not trigger the device. My problem is how to get the new entity ID of my Telldus switch. Is it possible to “convert” between the old ID and the new?
I have exactly the same problem,
I have been outside for a job for 6 months, HA 0.111 With HassOS was running fine, my wife used this all days.
Now iám back @home.
Made a snapshot in ESXI first ( I’am still running as test)
First update to HassOS 4.16 => OK
The Update 0.111 to 0.117 =Fail could not run anything, so i put back the snapshot.
Left it for a week.
Yesterday is updated again to 0.118.3 since this was the newest.
It took about 45 minutes to conevert but running ok now
My push buttons where easily found
But all my lights are not working, they are commented out the configuration.yaml
I uncommented them all but still no luck
So how do i add them to the RFXtrx device ?
( i do not have remote’s here, the most push buttons are zigbee inwall types)
Ok after searching websites i found a solution
add manually Rfxtrx Options
0B11001A0101010201010000:
Now i have to find a solution to change the device from
switch.ac_1010104_1 to Light
I found that i should change the last digit, but that seems not work for now, i have ARC sensor
for ARC sensors it should be 01 0F70 -> 02 0F70
for LIghtwaveRF it should be: 01 0F70 -> 10 0F70
Have you looked at the integration in the UI? The configuration of RFXtrx has moved into the UI. The first step of the change may have been in 0.113 (can’t remember exactly)
That’s when the config of devices moved under rfxtrx - instead of something like:
Then in 0.117 the rest of the config moved into the UI. It has probably imported your current config, but changes will now need to be made in the UI rather than the YAML files.
0710011443020100 Should be light and not switch, why is this made so difficulty ??
In my old 0.111 in configuration.yaml
0B1100060101010401010000:
#Arc13
Now in the new 0.118.3 add with the rfxtrx integration
Shown as a switch with uninteresting things like receive power and a binary switch
I only want Light.LampSerre and not use something like switch.ac_1010101_1
Strange that the other switch light " Bij TV" only works with switch.arc_c2 in the card , light.lamptv is not accepted
Maybe i do something wrong, but what i would like to have that i can set an alias name once in the rfxtrx integration page and use this alias name every where so that there is no need to do this in configuration .yaml.
