A year ago I needed to buy a new RFXTRX antenna because my rolling shades used a protocol not supported by the older antenna. Then I was forced to move from a Raspberry Pi 3+ to a Pi5 because it was no longer supported by Home Assistant. I have been gradually using the move to clean up old config, only migrating over what I still need. One of the last things was plugging in the RFXTRX into the USB port. And that’s when I found out that the RFXTRX is not supported anymore by the RPi 5. Something about an older FTDI chip that is not compatible with the Pi 5 USB‑stack.
This kind of seems contrary to Home Assistant wanting to be able to also use older devices. Is there something that can be done? Additional / backward compatibility built into Home Assistant?
AI research tells me to replace the FTDI chip, but I am a bit weary of that…
