Today I updated to Home Assistant version 0.84.2
The RFXTRX component is started, sensors are added.
But no messages are received anymore from the USB device.
In the logfile:
2018-12-14 14:49:37 INFO (MainThread) [homeassistant.loader] Loaded switch.rfxtrx from homeassistant.components.switch.rfxtrx
2018-12-14 14:49:38 INFO (MainThread) [homeassistant.loader] Loaded rfxtrx from homeassistant.components.rfxtrx
2018-12-14 14:49:38 INFO (MainThread) [homeassistant.setup] Setting up rfxtrx
2018-12-14 14:49:38 INFO (MainThread) [homeassistant.setup] Setup of domain rfxtrx took 0.4 seconds.
2018-12-14 14:49:38 INFO (MainThread) [homeassistant.components.switch] Setting up switch.rfxtrx
2018-12-14 14:49:38 DEBUG (Thread-14) [homeassistant.components.rfxtrx] Add keuken_sensor rfxtrx
2018-12-14 14:49:38 DEBUG (Thread-14) [homeassistant.components.rfxtrx] Add woonkamer_sensor rfxtrx
2018-12-14 14:49:38 DEBUG (Thread-14) [homeassistant.components.rfxtrx] Add deurbel rfxtrx
2018-12-14 14:49:47 INFO (MainThread) [homeassistant.loader] Loaded sensor.rfxtrx from homeassistant.components.sensor.rfxtrx
2018-12-14 14:49:49 INFO (MainThread) [homeassistant.components.sensor] Setting up sensor.rfxtrx
2018-12-14 14:49:49 INFO (Thread-5) [homeassistant.components.sensor.rfxtrx] Add temp_badkamer rfxtrx.sensor
2018-12-14 14:49:49 INFO (Thread-5) [homeassistant.components.sensor.rfxtrx] Add temp_tuin rfxtrx.sensor
2018-12-14 14:49:49 INFO (Thread-5) [homeassistant.components.sensor.rfxtrx] Add plant_sensor rfxtrx.sensor
2018-12-14 14:49:49 INFO (Thread-5) [homeassistant.components.sensor.rfxtrx] Add water_sensor rfxtrx.sensor
Is this component broken since the update?
