I am trying to setup RFXTRX. Seems that the device is added but no sensors are found… I check with RFXMGR (Windows) and then devices are found…
rfxtrx:
device: /dev/ttyUSB0
- platform: rfxtrx
automatic_add: true
Check that USB0 is RFXCOM
[ 2.222720] usb 1-1.2: Product: RFXtrx433
[ 2.224134] usb 1-1.2: Manufacturer: RFXCOM
[ 2.225550] usb 1-1.2: SerialNumber: A118TRKN
[ 2.574491] usb 1-1.2: FTDI USB Serial Device converter now attached to ttyUSB0
I see no devices added
I enabled debug loggging… see a lot of errors (with rfxtrx)… any idea ??
homeassistant/components/binary_sensor/.translations/rfxtrx.nl.json
2019-02-17 18:10:15 DEBUG (SyncWorker_5) [homeassistant.util.json] JSON file not found: /usr/local/lib/python3.6/site-packages/homeassistant/components/emulated_roku/.translations/nl.json
2019-02-17 18:10:15 DEBUG (SyncWorker_5) [homeassistant.util.json] JSON file not found: /usr/local/lib/python3.6/site-packages/homeassistant/components/cloud/.translations/nl.json
2019-02-17 18:10:15 DEBUG (SyncWorker_5) [homeassistant.util.json] JSON file not found: /usr/local/lib/python3.6/site-packages/homeassistant/components/tts/.translations/nl.json
2019-02-17 18:10:15 DEBUG (SyncWorker_5) [homeassistant.util.json] JSON file not found: /usr/local/lib/python3.6/site-packages/homeassistant/components/sensor/.translations/dsmr.nl.json
2019-02-17 18:10:15 DEBUG (SyncWorker_5) [homeassistant.util.json] JSON file not found: /usr/local/lib/python3.6/site-packages/homeassistant/components/.translations/logbook.nl.json
2019-02-17 18:10:15 DEBUG (SyncWorker_5) [homeassistant.util.json] JSON file not found: /usr/local/lib/python3.6/site-packages/homeassistant/components/switch/.translations/rfxtrx.nl.json
2019-02-17 18:10:15 DEBUG (SyncWorker_5) [homeassistant.util.json] JSON file not found: /usr/local/lib/python3.6/site-packages/homeassistant/components/config/.translations/device_registry.nl.json
2019-02-17 18:10:16 DEBUG (SyncWorker_5) [homeassistant.util.json] JSON file not found: /usr/local/lib/python3.6/site-packages/homeassistant/components/.translations/script.nl.json
2019-02-17 18:10:16 DEBUG (SyncWorker_5) [homeassistant.util.json] JSON file not found: /usr/local/lib/python3.6/site-packages/homeassistant/components/http/.translations/nl.json
2019-02-17 18:10:16 DEBUG (SyncWorker_5) [homeassistant.util.json] JSON file not found: /usr/local/lib/python3.6/site-packages/homeassistant/components/hassio/.translations/nl.json
2019-02-17 18:10:16 DEBUG (SyncWorker_10) [homeassistant.util.json] JSON file not found: /usr/local/lib/python3.6/site-packages/homeassistant/components/config/.translations/group.en.json
2019-02-17 18:10:16 DEBUG (SyncWorker_10) [homeassistant.util.json] JSON file not found: /usr/local/lib/python3.6/site-packages/homeassistant/components/.translations/introduction.en.json
2019-02-17 18:10:16 DEBUG (SyncWorker_10) [homeassistant.util.json] JSON file not found: /usr/local/lib/python3.6/site-packages/homeassistant/components/.translations/mqtt_statestream.en.json
2019-02-17 18:10:16 DEBUG (SyncWorker_10) [homeassistant.util.json] JSON file not found: /usr/local/lib/python3.6/site-packages/homeassistant/components/system_health/.translations/en.json
2019-02-17 18:10:16 DEBUG (SyncWorker_10) [homeassistant.util.json] JSON file not found: /usr/local/lib/python3.6/site-packages/homeassistant/components/light/.translations/rfxtrx.en.json
2019-02-17 18:10:17 DEBUG (SyncWorker_10) [homeassistant.util.json] JSON file not found: /usr/local/lib/python3.6/site-packages/homeassistant/components/websocket_api/.translations/en.json
2019-02-17 18:10:17 DEBUG (SyncWorker_10) [homeassistant.util.json] JSON file not found: /usr/local/lib/python3.6/site-packages/homeassistant/components/.translations/rfxtrx.en.json
2019-02-17 18:10:17 DEBUG (SyncWorker_10) [homeassistant.util.json] JSON file not found: /usr/local/lib/python3.6/site-packages/homeassistant/components/config/.translations/entity_registry.en.json
2019-02-17 18:10:17 DEBUG (SyncWorker_10) [homeassistant.util.json] JSON file not found: /usr/local/lib/python3.6/site-packages/homeassistant/components/switch/.translations/en.json
2019-02-17 18:10:17 DEBUG (SyncWorker_10) [homeassistant.util.json] JSON file not found: /usr/local/lib/python3.6/site-packages/homeassistant/components/.translations/history.en.json
2019-02-17 18:10:17 DEBUG (SyncWorker_10) [homeassistant.util.json] JSON file not found: /usr/local/lib/python3.6/site-packages/homeassistant/components/.translations/api.en.json
2019-02-17 18:10:17 DEBUG (SyncWorker_10) [homeassistant.util.json] JSON file not found: /usr/local/lib/python3.6/site-packages/homeassistant/components/binary_sensor/.translations/en.json
2019-02-17 18:10:17 DEBUG (SyncWorker_10) [homeassistant.util.json] JSON file not found: /usr/local/lib/python3.6/site-packages/homeassistant/components/group/.translations/en.json
2019-02-17 18:10:17 DEBUG (SyncWorker_10) [homeassistant.util.json] JSON file not found: /usr/local/lib/python3.6/site-packages/homeassistant/components/onboarding/.translations/en.json
2019-02-17 18:10:17 DEBUG (SyncWorker_10) [homeassistant.util.json] JSON file not found: /usr/local/lib/python3.6/site-packages/homeassistant/components/light/.translations/en.json
2019-02-17 18:10:17 DEBUG (SyncWorker_10) [homeassistant.util.json] JSON file not found: /usr/local/lib/python3.6/site-packages/homeassistant/components/config/.translations/config_entries.en.json
2019-02-17 18:10:17 DEBUG (SyncWorker_10) [homeassistant.util.json] JSON file not found: /usr/local/lib/python3.6/site-packages/homeassistant/components/config/.translations/automation.en.json
2019-02-17 18:10:18 DEBUG (SyncWorker_10) [homeassistant.util.json] JSON file not found: /usr/local/lib/python3.6/site-packages/homeassistant/components/config/.translations/auth_provider_homeassistant.en.json
2019-02-17 18:10:18 DEBUG (SyncWorker_10) [homeassistant.util.json] JSON file not found: /usr/local/lib/python3.6/site-packages/homeassistant/components/lovelace/.translations/en.json
2019-02-17 18:10:18 DEBUG (SyncWorker_10) [homeassistant.util.json] JSON file not found: /usr/local/lib/python3.6/site-packages/homeassistant/components/config/.translations/area_registry.en.json
2019-02-17 18:10:18 DEBUG (SyncWorker_10) [homeassistant.util.json] JSON file not found: /usr/local/lib/python3.6/site-packages/homeassistant/components/sensor/.translations/yr.en.json
2019-02-17 18:10:18 DEBUG (SyncWorker_10) [homeassistant.util.json] JSON file not found: /usr/local/lib/python3.6/site-packages/homeassistant/components/.translations/updater.en.json
2019-02-17 18:10:18 DEBUG (SyncWorker_10) [homeassistant.util.json] JSON file not found: /usr/local/lib/python3.6/site-packages/homeassistant/components/config/.translations/script.en.json
2019-02-17 18:10:18 DEBUG (SyncWorker_10) [homeassistant.util.json] JSON file not found: /usr/local/lib/python3.6/site-packages/homeassistant/components/recorder/.translations/en.json
2019-02-17 18:10:18 DEBUG (SyncWorker_10) [homeassistant.util.json] JSON file not found: /usr/local/lib/python3.6/site-packages/homeassistant/components/config/.translations/en.json
2019-02-17 18:10:18 DEBUG (SyncWorker_10) [homeassistant.util.json] JSON file not found: /usr/local/lib/python3.6/site-packages/homeassistant/components/sensor/.translations/rfxtrx.en.json
2019-02-17 18:10:18 DEBUG (SyncWorker_10) [homeassistant.util.json] JSON file not found: /usr/local/lib/python3.6/site-packages/homeassistant/components/conversation/.translations/en.json
2019-02-17 18:10:18 DEBUG (SyncWorker_10) [homeassistant.util.json] JSON file not found: /usr/local/lib/python3.6/site-packages/homeassistant/components/.translations/map.en.json
2019-02-17 18:10:18 DEBUG (SyncWorker_10) [homeassistant.util.json] JSON file not found: /usr/local/lib/python3.6/site-packages/homeassistant/components/.translations/sun.en.json
2019-02-17 18:10:19 DEBUG (SyncWorker_10) [homeassistant.util.json] JSON file not found: /usr/local/lib/python3.6/site-packages/homeassistant/components/frontend/.translations/en.json
2019-02-17 18:10:19 DEBUG (SyncWorker_10) [homeassistant.util.json] JSON file not found: /usr/local/lib/python3.6/site-packages/homeassistant/components/automation/.translations/en.json
2019-02-17 18:10:19 DEBUG (SyncWorker_10) [homeassistant.util.json] JSON file not found: /usr/local/lib/python3.6/site-packages/homeassistant/components/.translations/logger.en.json
2019-02-17 18:10:19 DEBUG (SyncWorker_10) [homeassistant.util.json] JSON file not found: /usr/local/lib/python3.6/site-packages/homeassistant/components/config/.translations/customize.en.json
2019-02-17 18:10:19 DEBUG (SyncWorker_10) [homeassistant.util.json] JSON file not found: /usr/local/lib/python3.6/site-packages/homeassistant/components/config/.translations/core.en.json
2019-02-17 18:10:19 DEBUG (SyncWorker_10) [homeassistant.util.json] JSON file not found: /usr/local/lib/python3.6/site-packages/homeassistant/components/system_log/.translations/en.json
2019-02-17 18:10:19 DEBUG (SyncWorker_10) [homeassistant.util.json] JSON file not found: /usr/local/lib/python3.6/site-packages/homeassistant/components/config/.translations/auth.en.json
2019-02-17 18:10:19 DEBUG (SyncWorker_10) [homeassistant.util.json] JSON file not found: /usr/local/lib/python3.6/site-packages/homeassistant/components/sensor/.translations/en.json
2019-02-17 18:10:19 DEBUG (SyncWorker_10) [homeassistant.util.json] JSON file not found: /usr/local/lib/python3.6/site-packages/homeassistant/components/binary_sensor/.translations/rfxtrx.en.json
2019-02-17 18:10:19 DEBUG (SyncWorker_10) [homeassistant.util.json] JSON file not found: /usr/local/lib/python3.6/site-packages/homeassistant/components/cloud/.translations/en.json
2019-02-17 18:10:19 DEBUG (SyncWorker_10) [homeassistant.util.json] JSON file not found: /usr/local/lib/python3.6/site-packages/homeassistant/components/tts/.translations/en.json
2019-02-17 18:10:19 DEBUG (SyncWorker_10) [homeassistant.util.json] JSON file not found: /usr/local/lib/python3.6/site-packages/homeassistant/components/sensor/.translations/dsmr.en.json
2019-02-17 18:10:19 DEBUG (SyncWorker_10) [homeassistant.util.json] JSON file not found: /usr/local/lib/python3.6/site-packages/homeassistant/components/.translations/logbook.en.json
2019-02-17 18:10:19 DEBUG (SyncWorker_10) [homeassistant.util.json] JSON file not found: /usr/local/lib/python3.6/site-packages/homeassistant/components/switch/.translations/rfxtrx.en.json
2019-02-17 18:10:19 DEBUG (SyncWorker_10) [homeassistant.util.json] JSON file not found: /usr/local/lib/python3.6/site-packages/homeassistant/components/config/.translations/device_registry.en.json
2019-02-17 18:10:20 DEBUG (SyncWorker_10) [homeassistant.util.json] JSON file not found: /usr/local/lib/python3.6/site-packages/homeassistant/components/.translations/script.en.json
2019-02-17 18:10:20 DEBUG (SyncWorker_10) [homeassistant.util.json] JSON file not found: /usr/local/lib/python3.6/site-packages/homeassistant/components/http/.translations/en.json
2019-02-17 18:10:20 DEBUG (SyncWorker_10) [homeassistant.util.json] JSON file not found: /usr/local/lib/python3.6/site-packages/homeassistant/components/hassio/.translations/en.json
