RFXtrx Promax switch (via IT protocol)
I would like to control a PROmax switch via de RFXtrx hub. When I use the RFXmanger software I am able to control the switch with the following setting:
Type: IT (FA500, PROmax,…)
ID: 00 01 01
Unit Code: A
Level: 1
But how do I add this switch in the configuration.yaml file? I have no idea how to translate the ID and unit code to a string that home assistant can use.
With the RFY protocol i’m able to generate a working sting with this setting: 071a0000[id][unit_code]
This does not seems to work with the IT protocol.
I hope someone has a good suggestion!
Best regards,
D3rax
In the latest RFXmngr you will see the hex code, for example:
Lighting5 command: 0A 14 0F 03 00 01 01 01 01 00 00
Packettype = Lighting5
subtype = IT
Sequence nbr = 3
ID = 0101 decimal:257
Unit = 1
Command = On
