I’m having problems with a RFXCOM especially the rfxtrx.send service. When I add it to my configuration and restart the RFXCOM is added as an integration and work as excepted so the hardware is found and is working.
But after a restart without changing anything the integration is still there but the rfxtrx.send service is not there anymore and there is an error in the logfile, but I can’t figure out whats the problem and Google couldn’t help me either.
I’ve had the same problem on two different systems / installs
Home Assistant 0.114.4 in the VM for a NUC
Home Assistant 0.114.4 running on a Synology (fredrike package)
Besides trying different installs I repeatedly start from scratch but always the same problem. Tried the device path as /dev/ttyUSB1 but same problem on both systems. Google and the search function did not come up with a sollution.
In short:
adding rfxtrx to the configuration, restart and the service is available.
restart without changing anything: rfxtrx.send service did not start
removing integration and restart: rfxtrx.send service is working again.
2020-09-07 10:59:09 ERROR (Thread-3) [root] Uncaught thread exception
File "/usr/local/lib/python3.8/threading.py", line 932, in _bootstrap_inner
self.run()
File "/usr/local/lib/python3.8/threading.py", line 870, in run
self._target(*self._args, **self._kwargs)
File "/usr/local/lib/python3.8/site-packages/RFXtrx/__init__.py", line 826, in _connect
self._status = self.send_get_status()
File "/usr/local/lib/python3.8/site-packages/RFXtrx/__init__.py", line 888, in send_get_status
return self.transport.receive_blocking()
File "/usr/local/lib/python3.8/site-packages/RFXtrx/__init__.py", line 661, in receive_blocking
return self.parse(pkt)
File "/usr/local/lib/python3.8/site-packages/RFXtrx/__init__.py", line 593, in parse
pkt = lowlevel.parse(data)
File "/usr/local/lib/python3.8/site-packages/RFXtrx/lowlevel.py", line 94, in parse
pkt.load_receive(data)
File "/usr/local/lib/python3.8/site-packages/RFXtrx/lowlevel.py", line 1445, in load_receive
self.seqnbr = data[3]
IndexError: bytearray index out of range
I deleted the log and restart HA but the lines aren’t in the log. Below is the whole log after restarting. There is more than last time.
I’m using a RFXCOM RFXtrx433E / Hardware version 1.3 / EXT firmware 1025 connected to a USB3 hub on a USB3 port.
2020-09-08 08:31:16 ERROR (Thread-4) [root] Uncaught thread exception
self.run()
File "/usr/local/lib/python3.8/site-packages/RFXtrx/__init__.py", line 825, in _connect
self.transport.reset()
File "/usr/local/lib/python3.8/site-packages/RFXtrx/__init__.py", line 678, in reset
self.send(b'\x0D\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00')
File "/usr/local/lib/python3.8/site-packages/RFXtrx/__init__.py", line 674, in send
self.serial.write(pkt)
AttributeError: 'NoneType' object has no attribute 'write'
2020-09-08 08:31:16 ERROR (Thread-3) [root] Uncaught thread exception
self.run()
2020-09-08 08:31:17 ERROR (MainThread) [homeassistant.config_entries] Error unloading entry RFXTRX for rfxtrx
File "/usr/src/homeassistant/homeassistant/config_entries.py", line 309, in async_unload
result = await component.async_unload_entry( # type: ignore
File "/usr/src/homeassistant/homeassistant/components/rfxtrx/__init__.py", line 202, in async_unload_entry
await hass.async_add_executor_job(rfx_object.close_connection)
File "/usr/local/lib/python3.8/concurrent/futures/thread.py", line 57, in run
File "/usr/local/lib/python3.8/site-packages/RFXtrx/__init__.py", line 854, in close_connection
self.transport.close()
File "/usr/local/lib/python3.8/site-packages/RFXtrx/__init__.py", line 685, in close
self.serial.close()
AttributeError: 'NoneType' object has no attribute 'close'
Maybe this has something to do with a recent update of HA?
I just got my rfxtrx433e delivered and set it up through the configuration.yaml, in my case /dev/ttyUSB0
My log also shows:
2020-09-09 20:20:40 ERROR (Thread-3) [root] Uncaught thread exception
self.run()
File "/usr/local/lib/python3.8/site-packages/RFXtrx/__init__.py", line 835, in _connect
self.send_start()
File "/usr/local/lib/python3.8/site-packages/RFXtrx/__init__.py", line 882, in send_start
File "/usr/local/lib/python3.8/site-packages/RFXtrx/lowlevel.py", line 1444, in load_receive
self.subtype = data[2]
(Just pasting it in case there IS a difference which I do not see.)
In my case it does not even connect when starting op HA, this immediately shows up in my log. I have
automatic_add: true
But nothing shows up within devices/entities (which I guess is logical).
Additional information: running HA within Docker on a Raspberry PI 4 with Raspberry Pi OS 64bit.
After restarting a few times I once got a different message:
serial.serialutil.SerialException: Attempting to use a port that is not open
But that’s not showing up anymore…
Edit:
Some extra information: just tried it outside the docker container with some python scripts and the transceiver is working correctly (yay), it receives the signals just fine.
Yes I see what you mean now. It was working for a while just now and was able to control my lights through HA, but after restarting (restarting HA through server controls, restarting docker container or reboot whole server) the results are highly unstable.
I think something goes wrong with unloading ha and releasing the serial connection. You could report an issue to Github, it gets better exposure there.
i run into the problem decribed in this thread and i tried using your workaround but no luck!
So delete the RFXCOM integration via UI
Than restart HA
Then remove the rfxcom integration from configuation.yaml
And restart HA
After tis sequence i have RFXCOM integration in the UI and the logfile keeps on showing the below
2020-09-29 13:28:37 ERROR (Thread-5) [root] Uncaught thread exception
File “/usr/local/lib/python3.8/threading.py”, line 932, in _bootstrap_inner
self.run()
File “/usr/local/lib/python3.8/threading.py”, line 870, in run
File “/usr/local/lib/python3.8/site-packages/RFXtrx/init.py”, line 825, in _connect
File “/usr/local/lib/python3.8/site-packages/RFXtrx/init.py”, line 678, in reset
self.send(b’\x0D\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00’)
File “/usr/local/lib/python3.8/site-packages/RFXtrx/init.py”, line 674, in send
AttributeError: ‘NoneType’ object has no attribute ‘write’
Do you have any idea how to fix this? I am strugling to get HA running togehter with my klikaanklikuit devices.
I run the latest version and no it didn’t work for me in the first place i started with homeassistant a little more than a month ago so i am rather new to this platform.
I am sure the RFXcom is correctly connected and installed on the synology nas. I installed the USB driver and i acn see the device ttyUSB0. I also see that the RFXcom does trigger signals when i use my current remote to actvate switches and lights. But the RFXcom integration of homeassistant is not picking anything up!
Any idea or sugestion what i could do to check a little further? Or would it be an idea to move into another direction for example install node-red as an add-on? Node-red is also able to work with a RFXcom integration.
Rob, you’re the man! That was my issue! Just made sure that i pass on the USB device and now when i trigger my remote control a new entity is there in the RFXcom integration!
