I have some rfxtrx devices (Somfy) and sometimes one command is not receive by one or another device. It was possible to set a “signal repetitions” parameter but it seems that its not possible anymore. Is it true ? Or is it me that I cant find it?
I know this is probably not what you want to hear but I have been messing with this protocol quite a bit. I can say the most likely issue with the motors not hearing the command is likely because of a mis-understanding of the overall protocol not the number of repeated frames. That being said I cannot help you with the RfxTrx but I can provide you with a solution that is stable, reliable, and inexpensive.
