rfxtrx stoped working, all my switches are gone!
worked for 6 months, stopped working from one day to the other. didn’t even update manually.
i have not changed ANYTHING (not even the slightest) so it cannot be a config issue with hass.io
rfxtrx module cannot be initialized because
FileNotFoundError: [Errno 2] No such file or directory: '/dev/ttyACM0'
with terminal and hassio hardware info
i found that its not ttyACM0 anymore but ttyUSB0, when i try it with this i get this stacktrace;
Error during setup of component rfxtrx
File "/usr/local/lib/python3.6/site-packages/homeassistant/setup.py", line 148, in _async_setup_component
component.setup, hass, processed_config) # type: ignore
File "/usr/local/lib/python3.6/concurrent/futures/thread.py", line 56, in run
File "/usr/local/lib/python3.6/site-packages/homeassistant/components/rfxtrx.py", line 101, in setup
rfx_object = rfxtrxmod.Connect(device, None, debug=debug)
File "/usr/local/lib/python3.6/site-packages/RFXtrx/__init__.py", line 718, in __init__
self.transport = transport_protocol(device, debug)
File "/usr/local/lib/python3.6/site-packages/RFXtrx/__init__.py", line 601, in __init__
self.connect()
File "/usr/local/lib/python3.6/site-packages/RFXtrx/__init__.py", line 606, in connect
self.serial = serial.Serial(self.port, 38400, timeout=0.1)
File "/usr/local/lib/python3.6/site-packages/serial/serialutil.py", line 182, in __init__
self.open()
File "/usr/local/lib/python3.6/site-packages/serial/serialposix.py", line 265, in open
self._update_dtr_state()
File "/usr/local/lib/python3.6/site-packages/serial/serialposix.py", line 595, in _update_dtr_state
fcntl.ioctl(self.fd, TIOCMBIS, TIOCM_DTR_str)
OSError: [Errno 5] I/O error
no light switching for me ):
anything i could fix here? what happend there?
