RFXTRX stopped working since 0.115.6 (or a version shortly before)
Hi all!
After updating to 0.115.6 (or maybe a version before that…) my RFXTRX (rfxcom) stopped working.
I checked that my VM still recognises the hardware. It’s still on /dev/serial/by-id/usb-RFXCOM_RFXtrx433_A13JM73-if00-port0
In HA the same USB port is recognised and the unchanged configuration.yaml says:
# RFXCOM
rfxtrx:
  device: /dev/serial/by-id/usb-RFXCOM_RFXtrx433_A13JM73-if00-port0
  automatic_add: true
  devices:
    # dimmer hoek
    0b1100010087e96201020f70:
    etc.
The RFXCOM RFXtrx integration is like it was.
When I test the hardware externally by using a 433mhz remote I see the orange light of the RFXCOM blinking; so that confirms it’s still receiving.
However when flipping a switch in HA nothing happens. It appears no signal is being sent.
I’m no tech wizard, so I need some help in troubleshooting!
Does anyone recognise this or can you help me dig any deeper?
Thanks! Ruben
FIXED!
DSMR Datalogger was somehow interfering. When this was updated to the latest version and reconfigured the RFXCOM worked again.
