Hi All,
I have a rfxcom to receive and transmit RF signals and I would like to open a garage door via Home Assistant. I tried to use the param automatic_add: true, but HA doesn’t spot it when a press the button in the remote.
On the RFXmngr only captures the signal if I check undec on and I’m able to reproduce the signal and open the door with RFXmngr triggering a raw package as explained in the rfxcom guide point 16.
Is there a way to give this raw data to HA? if not, how can I setup HA to use the same “DIPs” as the remote control
Do I understand correct, you are able to record RF sequence and then open your garage door with it? If so, your garage door receiver/remote pair use a fixed code, not rolling code protocol. It can be a serious security risk, as anyone can sniff the code sent by your remote and open your garage door.
