I am new to HA, I have setup my Raspberry Pi 3b and now am trying to get come cheap motion sensors that I acquired to work via my RXFTRX433E transceiver connected to the pi via USB.
I have enabled debugging in my configuration.yaml and put the RFXCOM in auto add mode:
default_config:
logger:
default: debug
logs:
homeassistant.components.rfxtrx: debug
homeassistant.components.binary_sensor.rfxtrx: debug
homeassistant:
unit_system: imperial
time_zone: America/Chicago
#433Mhz Transcevier
rfxtrx:
device: /dev/serial/by-id/usb-RFXCOM_RFXtrx433_A12IVCQJ-if00-port0
automatic_add: true
debug: True
I have cheap chinese motion sensors (https://www.amazon.com/gp/product/B073WTR8PW/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1) that I an trying to get to work.
When auto discover mode runs it appears that the sensor is getting detected (I have a ton of neighborhood 433MHz devices found).
The device that is mine has an ID of pt2262_505fc6
2020-10-01 20:06:20 DEBUG (MainThread) [homeassistant.helpers.restore_state] Created cache with ['person.scott_morgan', 'device_tracker.thedarknet_2', 'switch.pt2262_d05fc6', 'switch.pt2262_505fc6', 'binary_sensor.pt2262_505fc6', 'sensor.pt2262_505fc6_rssi_numeric', 'binary_sensor.pt2262_d05fc6', 'sensor.pt2262_d05fc6_rssi_numeric', 'binary_sensor.rm174rf_smoke_detector_3417f1_32', 'sensor.rm174rf_smoke_detector_3417f1_32_battery_numeric', 'sensor.rm174rf_smoke_detector_3417f1_32_sensor_status', 'sensor.rm174rf_smoke_detector_3417f1_32_rssi_numeric']
2020-10-01 20:06:30 DEBUG (MainThread) [homeassistant.core] Bus:Handling <Event state_changed[L]: entity_id=switch.pt2262_505fc6, old_state=None, new_state=<state switch.pt2262_505fc6=unavailable; restored=True, supported_features=0, friendly_name=PT2262 505fc6 @ 2020-10-01T20:06:30.844410-05:00>>
2020-10-01 20:06:30 DEBUG (MainThread) [homeassistant.core] Bus:Handling <Event state_changed[L]: entity_id=binary_sensor.pt2262_505fc6, old_state=None, new_state=<state binary_sensor.pt2262_505fc6=unavailable; restored=True, supported_features=0, friendly_name=PT2262 505fc6 @ 2020-10-01T20:06:30.846361-05:00>>
2020-10-01 20:06:30 DEBUG (MainThread) [homeassistant.core] Bus:Handling <Event state_changed[L]: entity_id=sensor.pt2262_505fc6_rssi_numeric, old_state=None, new_state=<state sensor.pt2262_505fc6_rssi_numeric=unavailable; restored=True, supported_features=0, device_class=signal_strength, unit_of_measurement=dBm, friendly_name=PT2262 505fc6 Rssi numeric @ 2020-10-01T20:06:30.847373-05:00>>
When I trigger the device with motion I am seeing this:
2020-10-01 20:06:30 DEBUG (MainThread) [homeassistant.components.websocket_api.http.connection.1811129320] Sending {'id': 2, 'type': 'event', 'event': <Event state_changed[L]: entity_id=switch.pt2262_505fc6, old_state=None, new_state=<state switch.pt2262_505fc6=unavailable; restored=True, supported_features=0, friendly_name=PT2262 505fc6 @ 2020-10-01T20:06:30.844410-05:00>>}
2020-10-01 20:06:30 DEBUG (MainThread) [homeassistant.components.websocket_api.http.connection.1811129320] Sending {'id': 2, 'type': 'event', 'event': <Event state_changed[L]: entity_id=binary_sensor.pt2262_505fc6, old_state=None, new_state=<state binary_sensor.pt2262_505fc6=unavailable; restored=True, supported_features=0, friendly_name=PT2262 505fc6 @ 2020-10-01T20:06:30.846361-05:00>>}
2020-10-01 20:06:30 DEBUG (MainThread) [homeassistant.components.websocket_api.http.connection.1811129320] Sending {'id': 2, 'type': 'event', 'event': <Event state_changed[L]: entity_id=sensor.pt2262_505fc6_rssi_numeric, old_state=None, new_state=<state sensor.pt2262_505fc6_rssi_numeric=unavailable; restored=True, supported_features=0, device_class=signal_strength, unit_of_measurement=dBm, friendly_name=PT2262 505fc6 Rssi numeric @ 2020-10-01T20:06:30.847373-05:00>>}
I tried adding this to the YAML to be able to get rid of the noise with auto discover:
devices:
Front Porch Motion
505fc6:
device_class: motion
off_delay:
seconds: 5
But when I do this the new added device doesn’t become available
Can anyone offer any advice?
