Rgb always has some white after .66
After I upgraded to .66 (and now .67) I can’t get full rgb colors on my rgbw bulb. Using the ui the extremes always have some white, where before I could get colors with no white included by being on the edge of the color disc. Any ideas?
No one else had seen this? Zwave rgbw bulb can’t hit full color (no white) using the ha ui anymore
Ok, so it seems that now the white value is no longer affected by the UI colorwheel where before it was. I would think the closer i get to the middle (white) the more white there would be. Is there a way to set the color wheel to set values for rgbw vs just rgb?
Ah it looks like a bug report was filed.
I’m not sure what the correct fix should be. Have the color wheel vary white_level based on distance from center. Or have the color wheel only adjust rgb and have another slider for white level like this:
I think I’d prefer the color wheel adjust white_level rather than having another slider…
