RGB control, template, automation
Hello
I am looking for automation, a template that would display a ‘color wheel’ on e.g. 14 lamps, i.e. a palette of colors from lamp 1 to 14, of course in a loop
I found something like this but it displays the ‘color wheel’ on 1 or several lamps at the same time.
Color Loop
I also found such a template but everything happens randomly and that is not what I want.
Party Lights
I will be very grateful for all advice and suggestions, the worst thing is that I have no idea what to call it and even less how to search for it.
Best regards
Hi!
In order to try to help you, i’d like a little more info on what you’re trying to achieve.
  • Are you looking for 14 specific colors on 14 specific (seperate) lights? Or do all 14 lights need to display the same color at the same time and then loop through the colors?
  • How much time do you want to have between any color changes?
  • Are the colors set? do you have an RGB value for each?
Hello
Sorry I’m only answering now but I was on the road.
The idea is to pass all the colors in the loop through all 14 lamps in turn, e.g. red was on lamp 1, it went from 1 to 2, from 2 to 3 and so on until 14 and from 14 back to 1. When a color goes out of 1, another color comes in. It would be nice if the speed of the changes could be regulated.
Best regards
