Rgb cooling hat
Hello good day
Does anyone have this module working in HA ?
Rgb cooling hat: http://www.yahboom.net/study/RGB_Cooling_HAT
I have try it with this info:Controlling cooling fan for Raspberry Pi 4
But the fan won’t do anything.
I added this to my config:
  • platform: rpi_gpio
    ports:
    18: RPI Cooling Fan
    Also the Raspberry Gpio installed .
    I did some measurements but I can’t find which pin controls the fan.
    I hope someone can help me, thanks in advance
Hello weske2000,
That is quite an old post so I am not surprised that does not work. rpi_gpio there is likely the stuff that was removed from core.
I am thinking that there is now one or more custom integrations to help with those functions available on GitHub thru HACS. You would have to search for them using HACS, I don’t not personally use a PI and do not know for certain.
Thanks for you reaction
i go try look again but have you any info about pins od my board ?
I Found now more info about the pin config
physical pin numbers 3 and 5, and IO voltage 3.3V
Gpio2: = rpi:pin3/Sda
Gpio3: = rpi:pin5/Scl
I try here
    ports:
    4: RPI Cooling Fan
    Pins:
    2
    3
    5
But fan wont running
can anyone help please ?
