Hi folks,
Newbie here, so please excuse me if the solution is obvious but I’m hitting the wall with this issue
I have a proper Home Assistant installation working with a ninja block using this ninja cape mqtt bridge (https://github.com/perrin7/ninjacape-mqtt-bridge), so temperature, humidity, buttons and plugs works fine but I’m not able to configure the ninja eyes…
The things is, I need to send the rgb values in hexadecimal as RRGGBB (so FF0000 for red), so I’ve created a mqtt_template entry as:
platform: mqtt_template
state_topic: "ninjaCape/input/1007"
command_topic: "ninjaCape/output/1007"
command_off_template: "000000"
command_on_template: "FFFFFF"
red_template: '{{ value[0] | int(base=16) }}'
green_template: '{{ value[1] | int(base=16) }}'
blue_template: '{{ value[2] | int(base=16) }}'
So, while turn them on and off works, color change fails as:
2017-07-25 16:37:47 ERROR (MainThread) [homeassistant.core] Error doing job: Exception in callback async_subscribe.<locals>.async_mqtt_topic_subscriber('ninjaCape/input/999', b'FFFFFF', 0) at /srv/homeassistant/lib/python3.4/site-packages/homeassistant/components/mqtt/__init__.py:207
File "/usr/lib/python3.4/asyncio/events.py", line 120, in _run
self._callback(*self._args)
File "/srv/homeassistant/lib/python3.4/site-packages/homeassistant/components/mqtt/__init__.py", line 226, in async_mqtt_topic_subscriber
hass.async_run_job(msg_callback, dp_topic, payload, dp_qos)
File "/srv/homeassistant/lib/python3.4/site-packages/homeassistant/core.py", line 245, in async_run_job
target(*args)
File "/srv/homeassistant/lib/python3.4/site-packages/homeassistant/components/light/mqtt_template.py", line 156, in state_received
async_render_with_possible_json_value(payload)
AttributeError: 'NoneType' object has no attribute 'async_render_with_possible_json_value'
So, what I think it is needed is to modify the value hass send to the mqtt so instead is an array of decimals [ red, green, blue] it is an hexadecimal number composed by those numbers… but it is obviously not what I’m doing
Doing it manually using mosquitto works fine:
mosquitto_pub -d -h 192.168.1.2 -t "ninjaCape/output/1007" -m "FF00FF" -V mqttv311
Using the template editor, this seems to work to extract the values:
{% set value="FF00FF" %}
{{ value[4:6] | int(base=16) }}
I’ve modified the light section as:
red_template: '{{ value[0:2] | int(base=16) }}'
green_template: '{{ value[2:4] | int(base=16) }}'
blue_template: '{{ value[4:6] | int(base=16) }}'
But it doesn’t work either.
Any clue?
