Hi all,
I recently acquired a Govee tv led kit. I like the set up of it and the control box, but as its not flash-able or hack-able I have done away with the control board and made my own based around a D1 mini.
All the buttons work the same but now it is easily integrated into home assistant.
The issue i’m having is the red led stays on constantly dim but easily visible this the case even when switched off.
It seems when there is 5v on the common and a positive voltage on the red channel it keeps it lit dim. This only happens with the red leds the greed and blue aren’t an issue.
The only difference I can see with the red to the others is the resistors on the strip are a different value on the red channel, I don’t know if this could be the issue.
Any input is appreciated
Thanks in advance.
