Hi! I just got Home Assistant to work here and started working on my first node! I got a NodeMCU device with a small neopixel led strip (generic WSXXXX strip). I can get the example on / off neopixel light to work just fine, but I was wondering: Is it possible to create a RGB light from this setup, but being able to control the RGB colors and brightness like you can do for the normal RGB Light component?
My idea is to use the neopixel strip as an actual RGB light, but having all those handy interface controls like you see in the https://esphome.io/components/light/rgb.html page. Is that possible? Thanks!
