I am trying to create a script to turn on an RGB light and set the brightness and color temperature based on two helper input_select dropdowns. When I reference them, I keep getting object errors. Here are the details:
One of the dropdowns:
input_select:
light_temperature:
name: Light Temperature
options:
- 2000
- 2500
- 3000
- 3500
- 4000
- 5000
- 6000
- 6535
Script:
alias: Zigbee Light 1
sequence:
- service: light.turn_on
metadata: {}
kelvin: "{{ states("input_select.light_temperature") }}"
brightness: "{{ states("input_select.light_brightness") }}"
entity_id: light.zigbee_1_light
mode: single
Results after I click save:
sequence:
metadata: {}
kelvin:
"[object Object]": null
brightness:
mode: single
I tried various different ways to pass the values and I get errors no matter what I try. I even created sensor helpers that reference the input_select helpers so there is only a single value and that does not work either. Please help.
