RGB Pool Lights
I have RGB pool lights connected to a Z-Wave switch. You change color on them by cycling the power to them a certain number of times depending on the color you want.
What is the best way to surface this up as a RGB switch to HomeKit with the HomeKit integration using some sort of an automation behind it that if a user picks red it does the appropriate power cycles to get to the red color for example.
Am I going to need to write a custom component for this, or is there a quicker way?
Just an automation is all that’s needed.
You might want to check in the blueprint exchange in case someone had already made a blueprint to do this. Sounds like something that could have happened.
Tips on Searching for Answers & Duplicate Topics in the Forum.
But I also need to somehow surface a light with the color options to chose from for it to work with HomeKit, I tried a template but that does t seem to do the trick.
I have no advice for dealing with that apple stuff, sorry. It’s not something I deal with.
