Bio1
December 12, 2022, 8:59pm
1
Hi all,
I have looked all day to try and find a RGBAW led controller.
And have come up short.
The goal is to run some 24volt rgbaw led’s
The options that I seem to find are to flash an esp with tasmoto or esphome.
So long story short does anyone know of a good five channel led controller?
Is the easy solution just to get a ZigBee dongle and a gledopto 5 in 1?
And if so is it possible to tell HA that it is an rgbaw fixture?
Thanks.
Akriss
(kris)
December 12, 2022, 9:12pm
2
A H801 controller would fit the bill nicely. 5-24v controller 5 channel
https://esphome.io/cookbook/h801.html
https://tasmota.github.io/docs/devices/H801/
Readily available for $10 USD -/+
Bio1
December 13, 2022, 8:36pm
3
Cool cool I will have a look — at the very least it is a cheap test.
Second question — is it possible to tell home assistant via esphome or tasmoto that it is RGBaw and not a normal white tunable ?
That part worries me more.
If it does not work. my plan is to just get a 4 channel zwave controller and not hook up the amber.
Akriss
(kris)
December 13, 2022, 9:15pm
4
It will work fine as is.
I think Amber and Warm White are close enough in the color spectrum for it not to matter much.
I have a H801 with Tasmota and in HA it look like:
The white slider is Amber to White, well cool white really.
And the warm white led on the strip I have could easily be called Amber as well.
Bio1
December 13, 2022, 9:54pm
5
awesome - i will let you know how it works out.
Still new to home assistant — currently just using it to control lutron lights.
Edit - corrected some grammar
