RGBgenie ZB-5001 automation
For integration with this remote: https://www.amazon.com/RGBgenie-Brightness-Control-Factory-Philips/dp/B07GBK3KPS
blueprint:
  name: RGBGenie 12 button
  description: Create automations for the RGBGenie
  domain: automation
  input:
    rgb_genie_device:
      description: "RGB Genie device"
      selector:
        device:
          integration: zha
          manufacturer: RGBgenie
          model: RGBgenie ZB-5001
    button_1_on:
      name: Button 1 - On
      description: "Action to run, when the button is pressed."
      default: []
      selector:
        action: {}
    button_1_off:
      name: Button 1 - Off
      default: []
      selector:
        action: {}
    button_2_on:
      name: Button 2 - On
      default: []
      selector:
        action: {}
    button_2_off:
      name: Button 2 - Off
      default: []
      selector:
        action: {}
    button_3_on:
      name: Button 3 - On
      default: []
      selector:
        action: {}
    button_3_off:
      name: Button 3 - Off
      default: []
      selector:
        action: {}
    button_4_on:
      name: Button 4 - On
      default: []
      selector:
        action: {}
    button_4_off:
      name: Button 4 - Off
      default: []
      selector:
        action: {}
    button_5_on:
      name: Button 5 - On
      default: []
      selector:
        action: {}
    button_5_off:
      name: Button 5 - Off
      default: []
      selector:
        action: {}
mode: single
max_exceeded: silent
  - platform: event
    event_type: zha_event
variables:
  device_id: !input rgb_genie_device
condition: "{{ trigger.event.data.device_id == device_id }}"
  - variables:
      button_id: "{{ trigger.event.data.endpoint_id }}"
      command: "{{ trigger.event.data.command }}"
  - choose:
      - conditions: '{{ button_id == 1 and command == "on"}}'
        sequence: !input "button_1_on"
      - conditions: '{{ button_id == 2 and command == "on"}}'
        sequence: !input "button_2_on"
      - conditions: '{{ button_id == 3 and command == "on"}}'
        sequence: !input "button_3_on"
      - conditions: '{{ button_id == 4 and command == "on"}}'
        sequence: !input "button_4_on"
      - conditions: '{{ button_id == 5 and command == "on"}}'
        sequence: !input "button_5_on"
      - conditions: '{{ button_id == 1 and command == "off"}}'
        sequence: !input "button_1_off"
      - conditions: '{{ button_id == 2 and command == "off"}}'
        sequence: !input "button_2_off"
      - conditions: '{{ button_id == 3 and command == "off"}}'
        sequence: !input "button_3_off"
      - conditions: '{{ button_id == 4 and command == "off"}}'
        sequence: !input "button_4_off"
      - conditions: '{{ button_id == 5 and command == "off"}}'
        sequence: !input "button_5_off"
