Hey everyone,
i finally got my sk6812 running thanks to you all and especially @DotNetDann !
They switch on white as they should, and i can control the brightness and color in HA, but when i choose any effect they get stuck in their current state, and wont respond anymore.
Can anyone give me a hint where i made a mistake?
Edit:
Ok, so the “solid” colors work fine, but only the “fire” and “twinkle” effects work.
I´m using the Sketch from @DotNetDann, and just changed the usual connection stuff.
Guess there is something wrong with the effects?
@DotNetDann I am trying your code and order the level shifter from amazon … but cant find a mosfet with same specs. I dont know enough about mosfets to choose a diff one … can you point to a suitable one on amazon. I am running 144 leds on 1 meter strip
It works perfect for the sk6812, only thing is that i’d like to have transitions working. Does anyone know how to implement it in the code? I would love to have a nice fade when turning the leds on/off and changing the brightness/ colors. And when needed, define a longer transition in home assistant like in a script or scene.
@DotNetDann been using this setup for a while now works really good, thanks for your time. do you happen to have anymore documentation on how to add new effects. novice with aurduino ide but have been trying with not much luck
Firstly, I’d like to thank you for your component.
Secondly, I’d like to ask you how it is possible to change settings of the program, so that when arduino is connected to wi-fi it would display status “turned on”. For example, for the white light?
