My RGBW LED modules from Fibaro are now shown as covers after updating to 2024.5.2 an zwavejs2mqtt, therefore they are not usable.
Is this a known issue of HA or from zwavejs2mqtt?
Thanks, it was working in 2024.5.1. I might have to downgrade.
If you can reproduce it, providing the information that Raman has asked for would help get the problem fixed.
I will check that tomorrow.
Unfortunately it stays like that even on 2024.5.0.
Reinterviewing all modules in Z2M fixes the issue permanently. I had to remove the covers manually, but that is to be expected.
this will be fixed by Fix zwave_js discovery logic for node device class by raman325 · Pull Request #117232 · home-assistant/core · GitHub
