RGBW - templating
Hi there,
I’m looking for someone who’s good in templating :slight_smile:
I’ve got RGBW led strip connected as 4 different inputs. I’d like to combine them so I can use color palette eg. GitHub - ljmerza/light-entity-card: Control any light or switch entity
This looks like something I am looking for:
As I understand, that’s what templating for. So I can combine things and let them become another entity so generic cards etc. would undederstand them.
Best regards,
K.M.
Explain how your four strips work. What are their entity IDs, and what settings can you adjust?
Hey @Troon, each entity represents different color (RGBW). I can change only their brightness.
My entities:
light.red
light.green
light.blue
light.white
Physically it’s the same led strip. so eg. if I max red and green then I get led strip yellow :slight_smile:
I would like to combine this into ‘single entity’ which supports RGBW and color palette.
I’ve done something like this so far:
light:
    lights:
      rgbw:
        friendly_name: "rgbw"
        rgb_template: (
          {{ state_attr('light.kwadrat_kuchnia_red', 'brightness')  }},
          {{ state_attr('light.kwadrat_kuchnia_green', 'brightness') }},
          {{ state_attr('light.kwadrat_kuchnia_blue', 'brightness') }}
        turn_on:
          service: light.turn_on
          entity_id: light.kwadrat_kuchnia_red, light.kwadrat_kuchnia_green, light.kwadrat_kuchnia_blue
        turn_off:
          service: light.turn_off
        set_rgb:
            rgbw_color:
              - "{{ state_attr('light.kwadrat_kuchnia_red', 'brightness')  }}"
              - "{{ state_attr('light.kwadrat_kuchnia_green', 'brightness') }}"
              - "{{ state_attr('light.kwadrat_kuchnia_blue', 'brightness') }}"
            effect: "Solid"
This let’s me all 4 colors to be turned on or off. However, I don’t know yet how to pass selected color from the gui to make led strip light this color.
You need the set_rgb call to be three separate light.turn_on calls, with the brightness set to the appropriate colour value.
…or use set_rgbw and four calls. Something like this, perhaps:
      set_rgbw:
        - service: light.turn_on
            brightness: "{{ r }}"
          entity_id: light.kwadrat_kuchnia_green
            brightness: "{{ g }}"
          entity_id: light.kwadrat_kuchnia_blue
            brightness: "{{ b }}"
          entity_id: light.kwadrat_kuchnia_white
            brightness: "{{ w }}"
Thx. I’ve pasted entire snippet here Dimmable RGBW leds, each color separate source - #4 by krismarc
