Hi.
I’m not sure what’s is wrong here, but I can’t change from white to color using color_interlock: true
I’m testing with and RGBWW downlight.
I’ve mapped colors:
PWM0 -> GPIO13 -> Warm White 5
PWM1 -> GPIO5 -> Cold White 4
PWM2 -> GPIO4 -> Red (R) 1
PWM3 -> GPIO15 ????
PWM4 -> GPIO12 -> Green (G) 2
PWM5 -> GPIO14 -> Blue (B) 3
Is tasmota, everything is working fine setting PWM channels and option 37 to 0.
Now, I’m trying to make it work in ESPHome.
First problem: I always see COLOR and WHITE controls in HA for this device. The correct way should be only color controls when “COLOR” is selected or only WHITE controls when “TEMPERATURE” is selected, right?
Second problem: If I set color_interlock to false (default), I can turn on white and color LED’s at the same time. I think this is the correct behavior for this setting.
If I set color_interlock to true, RGB LED’s are turned off and I can only control color temperature and brightness…BUT the color picker and color brightness still displayng in HA device. Even if I select “COLOR” in device settings, the buld still in white mode (warn or cold), doesn’t change to color, even selecting the color.
This is my actual configuration:
esphome:
platform: ESP8266
board: esp12e
wifi:
ssid: "Skynet"
password: !secret wifi_skynet_pwd
domain: '.skylocal'
manual_ip:
static_ip: 192.168.22.205
gateway: 192.168.22.1
subnet: 255.255.255.0
ap:
ssid: "Teste2 Hotspot"
password: "ABhyjlAovXqY"
captive_portal:
# Enable logging
logger:
# Enable Home Assistant API
api:
ota:
web_server:
port: 80
auth:
username: jmaurin
password: !secret web_server_pwd
light:
- platform: rgbww
red: r
green: g
blue: b
cold_white: cw
warm_white: ww
cold_white_color_temperature: 6536 K
warm_white_color_temperature: 2000 K
# Example output entry
output:
- platform: esp8266_pwm
pin: GPIO4
pin: GPIO12
pin: GPIO14
pin: GPIO5
pin: GPIO13
