I have Hassio installed with Rhasspy add on and Rhasspy satellite on a RPI 3. I managed to configure the satellite and I can see text recognized in the master (running on Hassio).
On the master I have Rhasspy configured with Intent handling for Home Assistant and I have the URL their as https://xxxxx.duckdns.org:8123
I created a long lived token and add it as it was not filled automatically
I used the same example in this link for the configuration and the problem am seeing in master Rhasspy log is below
[WARNING:2021-03-19 17:53:34,289] rhasspydialogue_hermes: No session for id 1819bbd9-9247-411d-a69f-95c237516f1d. Dropping recognition.
[DEBUG:2021-03-19 17:53:34,291] rhasspyhomeassistant_hermes: https://caha.duckdns.org:8123/api/intent/handle
[ERROR:2021-03-19 17:53:34,375] rhasspyhomeassistant_hermes: handle_home_assistant_intent
File "/usr/lib/rhasspy/rhasspy-homeassistant-hermes/rhasspyhomeassistant_hermes/__init__.py", line 169, in handle_home_assistant_intent
response.raise_for_status()
File "/usr/lib/rhasspy/.venv/lib/python3.7/site-packages/aiohttp/client_reqrep.py", line 946, in raise_for_status
headers=self.headers)
aiohttp.client_exceptions.ClientResponseError: 404, message='Not Found', url=URL('https://xxxxx.duckdns.org:8123/api/intent/handle')
[ERROR:2021-03-19 17:53:34,376] rhasspyhomeassistant_hermes: handle_intent
File "/usr/lib/rhasspy/rhasspy-homeassistant-hermes/rhasspyhomeassistant_hermes/__init__.py", line 88, in handle_intent
assert response_dict, f"No response from {self.url}"
AssertionError: No response from https://xxxx.duckdns.org:8123
[ERROR:2021-03-19 17:53:34,377] asyncio: SSL error in data received
protocol: <asyncio.sslproto.SSLProtocol object at 0x7fafa42fd860>
transport: <_SelectorSocketTransport fd=12 read=polling write=<idle, bufsize=0>>
File "/usr/lib/python3.7/asyncio/sslproto.py", line 526, in data_received
ssldata, appdata = self._sslpipe.feed_ssldata(data)
File "/usr/lib/python3.7/asyncio/sslproto.py", line 207, in feed_ssldata
self._sslobj.unwrap()
File "/usr/lib/python3.7/ssl.py", line 767, in unwrap
return self._sslobj.shutdown()
ssl.SSLError: [SSL: KRB5_S_INIT] application data after close notify (_ssl.c:2609)
I’m only new at HA and Rhasspy myself, and have the same issue trying to guess what is the correct URL for Intent Handling.
For communication between the HA server and a satellite … since both are on your LAN and hence totally under your control, I am using their LAN IP addresses directly (e.g. http://192.168.1.98:8123/api/intent/handle ) rather than adding a step to lookup a DNS name (the xxxx.duckdns.org in your logs).
Also, I suspect the xxxx part is intended to be changed to your personal value.
I have managed (I don’t know how) to go from a 404 error to a 401 error, which I think is a step forward. I am happy to compare notes/configurations if you wish.
but I can’t get rid of the red [Save and restart required] button.
On rem1 I am getting
[ERROR:2021-05-16 18:25:25,222] rhasspyhomeassistant_hermes: handle_home_assistant_intent
File "/usr/lib/rhasspy/usr/local/lib/python3.7/site-packages/aiohttp/client_reqrep.py", line 1005, in raise_for_status
headers=self.headers,
aiohttp.client_exceptions.ClientResponseError: 401, message='Unauthorized', url=URL('http://192.168.1.98:8123/api/intent/handle')
[ERROR:2021-05-16 18:25:25,227] rhasspyhomeassistant_hermes: handle_intent
AssertionError: No response from http://192.168.1.98:8123/
[ERROR:2021-05-16 18:25:50,068] rhasspydialogue_hermes: Session timed out for site rem1: rem1-porcupine_raspberry-pi-43141092-047b-4be3-8764-90ebf95640b8
401 error indicates that the URL exists, but that the file being called on the server has incorrect access permissions ? The server is running HASS OS, so I can’t even check it.
How did you get yours working ? change to sending events instead of intents ?
Do you have the line below in your configuration.yaml of HA ?
intent:
Is this a satellite server of the add-on on HA ?.
If it is the former then Intent handling shouldn’t be enabled, if it is the latter use the following URL for hass http://hassio/homeassistant/
