Rheem Econet - monitor aux_heat status
@w1ll1am23
I have an Econet thermostat on my heatpump/gas furnace. I just had an issue where I discovered it had been set up incorrectly and was using the furnace way too often.
I can see the aux_heat attribute in Developer Tools under climate.thermostat and I realise that I can turn the furnace on and off through the integration. What I want to be able to do is see when the the system itself turns on and turns off the furnace and possibly set a notification alerts.
Is this possible at all?
